1958 nose job
Page: 1, 2  Next
1960bus
1960bus is offline
PostPosted: Sun Aug 23, 2015 2:04 pm    Post subject: 1958 nose job Reply with quote
Well I bit the bullet and bare metalled the nose of my car. I didn't really find anything I didn't expect. The nose has been hit and beaten out and had filler to smooth out. The nose ridge isn't good. Should I replace the nose or start hammering? I was planning on buying a shrinking disc anyway. The nose has some brazing in two places one on the nose ridge and one on the right nostril.
I bought a new nose for a later car but I'd have to add the nostrils to it. Has anyone brought one this bad back from the dead?
I also melted the lead off my headlight revealing a lovely crease. I have a stud welder and slide hammer that will get this straight.
Dan
1958 Ghia Vert
1960 RHD Deluxe Microbus
1966 RHD Devon Kombi
View user's profile Send private message AIM Address Gallery Classifieds Feedback
VeloMikey
VeloMikey is offline
PostPosted: Sun Aug 23, 2015 9:45 pm    Post subject: Reply with quote
Your nose is not that bad. Here is a link on how to make a nose ridge tool. http://youtu.be/CKtOTomWT_o I would knock the headlight bucket out, repair the crease with a hammer and dolly and spot the bucket back in. We are in the same boat, a PO smoothed out my ridge probably to Cal Look it out in the 80s and some genius drilled a dozen holes above my driver's headlight to "pull" a dent.
djway3474
djway3474 is offline
PostPosted: Sun Aug 23, 2015 11:34 pm    Post subject: Reply with quote
I made a nose ridge tool, two part, but I had to make an entire new ridge and weld it in.. I took out both buckets and in my case made new buckets starting with what was available at the time. It winds up being much easier.
Have a blast Very Happy
1960bus
1960bus is offline
PostPosted: Mon Aug 24, 2015 4:53 am    Post subject: Reply with quote
I think I'll try to smooth it and make a ridge tool then. If it doesn't work out I can always replace it with the new nose.
Dan
1958 Ghia Vert
Mellow Yellow 74
Mellow Yellow 74 is offline
PostPosted: Tue Aug 25, 2015 4:52 am    Post subject: Reply with quote
The nose doesn't look too bad to me - you should be able to fix it with a lot less effort than replacing it
1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon)
technik
technik is offline
PostPosted: Tue Aug 25, 2015 4:04 pm    Post subject: Reply with quote
you reckon?
thats a lot of work to fix, especially if he wants the inside of the nose to look undamaged.
bluedot
bluedot is offline
PostPosted: Fri Aug 28, 2015 9:23 am    Post subject: Reply with quote
Replace.
1960bus
1960bus is offline
PostPosted: Sat Aug 29, 2015 2:07 pm    Post subject: Reply with quote
I'm going try my shrinking disc and planishing hammers for a couple of days to see how good I can get it. Tig welding in a new nose isn't going to be easy either.
Dan
1958 Ghia Vert
1960bus
1960bus is offline
PostPosted: Sat Sep 05, 2015 12:08 pm    Post subject: Reply with quote
An hour with a hammer, dolly and shrinking disc and it is slowly coming back to smooth.
Dan
1958 Ghia Vert
CiderGuy
CiderGuy is offline
PostPosted: Sat Sep 05, 2015 3:49 pm    Post subject: Reply with quote
Very nice work, looking good.
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything
Mellow Yellow 74
PostPosted: Sun Sep 06, 2015 4:07 am    Post subject: Reply with quote
It is looking better already. I spent about an hour with the hammer and dolly on my front fender this weekend and it has made a big difference. Some people don't understand how much you can do with a hammer and dolly and some basic skills.
1962 Karmann Ghia
1960bus
1960bus is offline
PostPosted: Thu Sep 17, 2015 2:17 pm    Post subject: Reply with quote
I had a left side lower fender from wolf parts but they don't make them anymore. I know Danny makes some superb pieces but I thought I'd give it a shot. This is my first Hammerform for the lower right fender I only have hand tools a vice and some scrap mdf. My first test already came out pretty well.
Dan
1958 Ghia Vert
VeloMikey
PostPosted: Thu Sep 17, 2015 2:25 pm    Post subject: Reply with quote
Excellent work!
1960bus
1960bus is offline
PostPosted: Thu Sep 17, 2015 2:47 pm    Post subject: Reply with quote
I need to shrink the edge on the lower part better than I have. I wish I had an oxy acetylene set. I wonder if mapp gas would work.
Dan
1958 Ghia Vert
kgj
kgj is offline
PostPosted: Fri Sep 18, 2015 12:14 am    Post subject: Reply with quote
Hi from the uk too.
I'm no expert but I really like the hammerform idea, thanks for posting.
On your recommendation I think I will get a shrinking disc myself. Please post plenty of photos as I am about to start on the nose of my 58 coupe too.
1958 coupe
djway3474
PostPosted: Fri Sep 18, 2015 1:00 am    Post subject: Reply with quote
Very Cool. I made just the nose ridge with a home made tool and I had never shaped a piece of metal before. You should have no problem.
1960bus
1960bus is offline
PostPosted: Fri Sep 18, 2015 10:33 am    Post subject: Reply with quote
I got my shrinking disc from stakesys. I bought the small one for a 4.5 inch grinder to get into a tight spot. I think I probably should have bought the bigger one first though for my big grinder as it would be a lot faster.
Dan
1958 Ghia Vert
cracker666
cracker666 is offline
PostPosted: Fri Sep 18, 2015 11:25 am    Post subject: Reply with quote
Steaksys and axminster do some decent kit.
look out on the bay for shrinker stretchers they are useful bits of kit.
1960bus
1960bus is offline
PostPosted: Sun Sep 20, 2015 8:57 am    Post subject: Reply with quote
Finished panel. I wish I had a shrinker I had to do it by hand tuck shrinking using the. Tucking forks I made.
Dan
1958 Ghia Vert
Mellow Yellow 74
PostPosted: Sun Sep 20, 2015 2:05 pm    Post subject: Reply with quote
You have done a professional job without professional workshop tools such as a folder, roller and shrinker so well done. I am not familiar with tucking forks - do you use these to "wrinkle" the edge and the hammer and dolly it smooth to shrink?
1962 Karmann Ghia
Last edited by Mellow Yellow 74 on Sun Sep 20, 2015 6:19 pm; edited 1 time in total
Page: 1, 2  Next
Page 1 of 2
