filmfolks Samba Member
Posted: Wed Feb 08, 2023 1:54 pm Post subject: Cofap Damper Super Stiff Bad Unit or Newb Mistake |
Hi All,
Just finished up a new front suspension install in the 70 Ghia, yea little details left but..
My Cofap Damper is crazy stiff. Extending out by hand is a really really hard to pull out but pushing back back in has less tension, and feels more like what a new stiff Damper should do. I had assumed a more even push pull. In fact the pretty gross old Boge damper feels like a damper should with an even in and out.
I did the hold vertical and prime by ext retract etc.
did I screw something up? Are they sometimes bad? is this normal?
The front end is really tight with no damper and all the new ball joints tie rods etc as expected , steering is not binding and triple checked. With the damper installed its almost impossible to turn.
Any guidance appreciated. |
TDCTDI Samba Advocatus Diaboli
Joined: August 31, 2013 Posts: 13286 Location: North Carolina
Posted: Wed Feb 08, 2023 3:14 pm Post subject: Re: Cofap Damper Super Stiff Bad Unit or Newb Mistake |
Sounds like itâs a gas pressure unit. If so, that would be normal. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
GOFUNDYOURSELF, quit asking everyone to do it for you!
An air cooled VW will make you a hoarder.
Do something, anything, to your project every day, and you will eventually complete it. |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2928 Location: Auckland, New Zealand
Posted: Wed Feb 08, 2023 3:59 pm Post subject: Re: Cofap Damper Super Stiff Bad Unit or Newb Mistake |
My Ghia has brand new ball-joints, and the steering is unbelievably stiff. But I was warned that would be the case. Apparently the ball-joints need to be "run in". _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6037 Location: 37.5N 77.1W
Posted: Thu Feb 09, 2023 8:54 am Post subject: Re: Cofap Damper Super Stiff Bad Unit or Newb Mistake |
Quote: |
pull out but pushing back |
The way I 'test' a steering damper to see if it's any good is to get the rod about half way out (straight ahead position) and vigorously push and pull as fast as I can. Any pause, travel of the rod, before resistance is felt means it's worn. I do it this way as it 'simulates' going over RR tracks when the damper is needed. _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
Posted: Fri Feb 10, 2023 2:26 pm Post subject: Re: Cofap Damper Super Stiff Bad Unit or Newb Mistake |
TDCTDI wrote: |
Sounds like itâs a gas pressure unit. If so, that would be normal. |
Thanks, seems odd that it would do that as it would be harder to turn one direction and not the other. |
Posted: Fri Feb 10, 2023 2:27 pm Post subject: Re: Cofap Damper Super Stiff Bad Unit or Newb Mistake |
kiwighia68 wrote: |
My Ghia has brand new ball-joints, and the steering is unbelievably stiff. But I was warned that would be the case. Apparently the ball-joints need to be "run in". |
Thank you. Its the damper out of the vehicle. |
Posted: Fri Feb 10, 2023 2:28 pm Post subject: Re: Cofap Damper Super Stiff Bad Unit or Newb Mistake |
runamoc wrote: |
The way I 'test' a steering damper to see if it's any good is to get the rod about half way out (straight ahead position) and vigorously push and pull as fast as I can. Any pause, travel of the rod, before resistance is felt means it's worn. I do it this way as it 'simulates' going over RR tracks when the damper is needed. |
yes thank you. The old damper was bad this one is brand new. |
