cjara111 Samba Member
Posted: Sat Jan 02, 2016 2:53 pm Post subject: How do I rienforce the front end of a Convertible? |
I have a huge concern. I am restoring a 1970 CV Karmann.
The rockers were in very bad condition, so I decided to go with the 2âx3â reinforcement, which I got from this site. After welding the 2x3, and an L beam on both sides of the car, I noticed that if I push the body forward from the windshield frame the carâs front end BENDS upward!!!
Here is what I have done and an illustration of the problem.
So now here is an illustration of the problem:
Does anyone have any suggestions??? Here are a couple of pics of what I see from the inside of the car :
I see some holes created by rust next to the pedals. Welding some reinforcement plates on the inside the car is my only idea, I am open to suggestions.....  |
Exaktaphile Samba Member
Posted: Sat Jan 02, 2016 3:42 pm Post subject: Re: How do I rienforce the front end of a Convertible? |
You need to extend the structural wall behind the hinge pillar down to a point even with the bottom seam of the rockers. Then, extend your home-made support forwards to overlap the hinge pillar wall. Weld the heck out of it after you're positive everything is aligned.
Also, make sure the top still fits and latches properly before welding the hinge pillar.
That's what provides the structural support at the hinge pillar on cars with factory parts (combined with the center divider and dogleg parts all welded to that wall). Plus of course, the floor pan bolts. Hope that helps!
Edit: I also notice you don't have any bracing on the door openings to prevent the body and door gaps from shifting around. Be prepared to have some problems getting a proper fit. |
Posted: Sat Jan 02, 2016 6:57 pm Post subject: Re: How do I rienforce the front end of a Convertible? |
If I understand you, instead of welding from inside the cockpit of the car you mean do it from the wheel well.
Reinforce the wall inside the fender and weld that to the 2x3 support. Right?
Thanks for the idea. |
Posted: Mon Jan 04, 2016 10:15 am Post subject: Re: How do I rienforce the front end of a Convertible? |
Great feedback. I guess the problem starts from the fact that I did not want to remove the body from the base. I have a couple of ideas on what to do. I will post some pics in the future. |
