porkchop-rob Samba Member
Posted: Yesterday 9:26 am Post subject: DRLA Jetting |
I am looking for help with a starting point for setup/jetting on some DRLA 36s for my son's Baja.
The engine is this:
1956cc - 76x90.5
Engle FK-42 Cam
1.4:1 Rockers
CB Panchito Heads (40x35.5, CNC Chamber, dual valve springs)
Magnaspark Distributor and coil
1 1/2" Baja header with resonator/muffler (straight through)
Dual Dellorto 36s _________________ 1965 Beetle
1968 Beetle Baja (Son's First Car)
1976 Bus with Subaru (Wife's Riviera Camper) |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 4118 Location: Georgia
Posted: Yesterday 12:00 pm Post subject: Re: DRLA Jetting |
36s are on the small side for that size engine. Mostly used on 1600-1776 engines but maybe theyâll be ok.
Iâll take a look at my Dellorto book and see what it says about venturi size etc and report back _________________ Volkswagen!
âLet he that is without oil throw the first rodâ
(Compression 8.7:1) |
Posted: Yesterday 12:19 pm Post subject: Re: DRLA Jetting |
jeffrey8164 wrote: |
Iâll take a look at my Dellorto book and see what it says about venturi size etc and report back |
Thank You! _________________ 1965 Beetle
Posted: Yesterday 1:33 pm Post subject: Re: DRLA Jetting |
Ok so having a look at the book and some parts suppliers hereâs what Iâve found.
For your 1956 youâre looking at 36mm venturis which should be good to around 5500 rpm.
Dellorto Parts UK only lists 32mm as the largest available for 36s but CB lists a 36mm vent but I havenât called them to find out if thatâs actually true or available.
If your current 36s still have factory stuff you should have:
30 Vents
180 Air
122 Main
60 Idle
50 ACC pump
If the 36mm vents are true and available, you should start with 150 mains and 65 idles. Leave the Airs and the pumps the same.
These are all just theoretical numbers based on math so Iâd get some extra extra idles, one step down and maybe 2 steps up and a step above on the mains.
If you find that the largest vent is only a 32mm then youâre in the market for larger carbs as 32s will suffer above 4500 rpm no matter the jetting.
If Iâm wrong Iâm sure someone else will chime in.
Hope this helps. _________________ Volkswagen!
Posted: Today 10:41 am Post subject: Re: DRLA Jetting |
Ok so...Hope this helps. |
You are the MAN!
I Greatly appreciate your efforts. I will pull them apart and report back on the findings.
That said, this is in my son's car, unless there is some reliability concern...I am completely okay with her running out of breath at 5000 RPMs. _________________ 1965 Beetle
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4919 Location: sanger ca
Posted: Today 12:03 pm Post subject: Re: DRLA Jetting |
36mm vent in a 36mm carb???? _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
