Odd transmission noise
Forum Index -> Vanagon Share: Facebook Twitter
hop2itinaz
hop2itinaz is offline
PostPosted: Today 9:33 am    Post subject: Odd transmission noise Reply with quote
Greetings All
I have a unique noise happening with my transmission on my 86 Westfalia. Subie 2.2 motor. Installed a Steedle rebuilt trans about 30k ago. A very comprehensive build (oiler plates, new gear carrier and well…pretty much new everything else).
Lately I am hearing a buzzing sound while coasting…in gear….clutch pressed. It sounds like a faint whirring noise as I decelerate that stops once stopped. If I am in say second gear it is clearly more pronounced than if I am in say third so it is definitely in gear train. If in NEUTRAL no noise. If I am standing still at idle I hear nothing with clutch pressed or not. Shifts fine. No howls or whines at highways speed and in fact quite smooth.
This is a new one to me. A fellow Vanagon group member has allowed me use of a good used trans while I get this one dialed in but wondering if anyone may have experience with this type of symptom.
Thanks!
Michael
MarkWard
MarkWard is offline
PostPosted: Today 10:35 am    Post subject: Re: Odd transmission noise Reply with quote
I’d reach out to Matt. Maybe record the sound. There used to be a German member that was very hands on with these transaxles. His experience was to go through them every 60,000 miles.
hop2itinaz
PostPosted: Today 11:27 am    Post subject: Re: Odd transmission noise Reply with quote
Already did that. He is definitely going to help if needed. I posted this more to get an idea if there is potentially something ELSE I should check prior to bothering Matt with opening this unit up again.
M
Sodo
Sodo is offline
PostPosted: Today 11:37 am    Post subject: Re: Odd transmission noise Reply with quote
What does the drain magnet look like? Pics?
Sometimes a 1st/2nd hub cracks, but seldom, thus often re-used.
You are 10 easy bolts from looking at the R&P.
'90 Westy EJ25, NEW oil rings (!) 2Peloquins, 3knobs, pressure-oiled GT mainshaft, filtered, cooled gearbox
'87 Tintop w 47k 53k, '12 SmallCar EJ25, cooled filtered gearbox
....KTMs, GasGas, SPOT mtb
?Waldo?
?Waldo? is offline
PostPosted: Today 12:00 pm    Post subject: Re: Odd transmission noise Reply with quote
What about the pilot bearing? If I'm not mistaken, it seems like it might fit the described behavior. While coasting in gear the input shaft spins (at a different speed from the crank). Higher gears would have the input shaft spinning slower (less noise?). In neutral, the input shaft is not spun by the trans (no noise). No noise when stopped might not fit as the input shaft would be stopped, but the crank would not.
Reply to topic    Forum Index -> Vanagon All times are Mountain Standard Time/Pacific Daylight Savings Time
