I had to replace the middle belt. I have the correct belt, have it on correctly but now the blades engage with the deck up. What would cause this?
If you replaced the belt yourself, the thing that comes immediately to mind is what I answered another question about a mower blade that was always engaged after a belt change - the belt might be inside-out: https://gardening.stackexchange.com/questions/20375/after-replacing-belt-la125-blades-are-always-engaged – That Idiot Apr 30 '19 at 11:24
I do not know that mower, but I assume the sensor on the back to detect if the deck up is maybe in the wrong position (maybe just by moving/tilling the mower). Try to move it up down (on inside, out). And check again.
Eventually you should check the wire which connect it. Maybe now it do a longer "travel" (maybe installing the belt, you moved it). Ev. check and adjust the cable length (check on both side, there should be a mechanism. Note: the true cable could be hidden on a protective tube.
It is in any case difficult to diagnose and explain what to do, from an internet site (and from a person who do no know your model). Try to touch and move different cables (not too strong, only the cables that go toward the back/bottom, not cables on motor/batteries/etc.), to see if they were blocked.
- 14,267
- 3
- 20
- 44
