I have water running into my crawl space and part of the reason I believe is from hill run-off above my house. I have 3.5ft high retaining wall all around the uphill side and water comes up underneath and thru it like little fountains and / or over the top of it during rain storms. My soil is very much clay, mixed with odd layers of sand. Various spots have sandstone, which is what my house is built on.
Here is a picture looking down from the uphill side on the problematic area where I've started digging my proposed trench.
Here is a picture looking up at the problem area from down the hill. The hill continues to drop another 12ft of elevation behind me in these tiered railroad tie walls. My proposed trench is on the left and the RR Tie Wall is left of that. Concrete retaining wall sticks out 12ft to the right. The ground here is full of sink holes due to run off / rivers coming over the tiers as well as up and underneath the other side of the concrete wall.
I have a 5 day break from rain. The question is basically as stated - is it ok to put the french drain there at/near the base of the wall where you see I started digging it or am I risking eroding the underneath / base of the wall? And, how deep should my trench be? I was thinking of just encasing perforated pipe in pea gravel a few inches below the surface and finishing off the top with 1-2 inch stone. I guess I'm going to have to dig underneath the tiered walls going down the hill or rip them out in order to get my drain going further down the hill.
maplemale
  • 255
If you compare the cost of perforated drain pipe with sleeve and the possibilities of water damage then more drain pipe is better. I am a big fan of four inch perforated drain pipe with sleeve as a solution for water runoff. Usage is described here and here and here.
For your issue I recommend two trenches, one parallel to the house foundation and the other parallel to the retaining wall. Ensure you have a slope in the trench downwards. If possible dig under the railway ties acting as stair risers and feed the pipe downwards. A french drain described in my other answers would be a logical termination for both drain pipes if you can dig down two or three feet.
Be sure to get the drain pipe with a sleeve and use crushed gravel with no fines underneath the pipe. You mentioned pea stone which will compact more than gravel.
I attach an extremely poor diagram, thank you Paint 3D, showing what I propose. drain pipe run
  • Haha! Well, it go the idea across. So, turns out i have an old clogged perforated line up against the foundation that both rain gutters are dumping into. The one on the lower corner, i'm not sure how deep it is. I stopped digging at 4ft / gave up. But, right below where you mark "French drain" I found it again going vertical and at that point it's no longer perforated and is full of water about 2ft down. I'm really confused now what was done before, but probably will abandon that in favor y our idea + re-do the rain gutter and add the 2 drains like you suggest - terminating them all as marked. – maplemale Dec 13 '17 at 00:54
  • I'm actually second guessing the french drain termination there... The amount of water is more like a creek when it rains. I could easily see the left side pipe (bottom picture) being nearly full for weeks on end / non stop when it rains. There is a creek another 100ft a (40ft elevation below picture) down the hill. Maybe I should just switch to more like a 8 inch flex / culvert line at the bottom of the picture and carry it to the creek. A lot more work / money. But, I'm thinking the french drain will just turn into surface water? – maplemale Dec 13 '17 at 01:10
  • Hi Kevinsky! I followed your answer easily. The only ONLY problem is that pea gravel does not compact. Crushed gravel does compact if compacted with a compactor or that gravel gets walked or weight applied to the surface. This drain stuff is a job for drain rock, less expensive and will never compact. Rounded rock doesn't compact. Crushed gravel with hard angles and fines...will compact. – stormy Dec 13 '17 at 04:47
  • @stormy that's why I said "crushed gravel with no fines". You are right, any substrate will compact, particularly with foot traffic – kevinskio Dec 13 '17 at 12:14
  • @maplemale I am glad you see the need for proper drainage for the foundation of your home. I would not link those roof gutters to the foundation drains. Those I would daylight over concrete shields as long as that water moves away from the house. The idea for foundation drains is to be able to move any water that gets near the foundation. To use foundation drains for any other purpose such as the water coming off the roof means you are actually directing water TO your foundation. Do not directly drain anything into a creek or river. It will eventually get there anyway as subsurface H2O. – stormy Dec 13 '17 at 22:07
  • If I knew more about your property...I am thinking you might want to design a 'dry creek' that would effectively and aesthetically form a function during times of rain. Perhaps even a 'rain garden'? A little meandering cobble filled stream (landscape fabric beneath the stone)...the meandering slows the water and either dumps into a 'dry well' or a pond or bog 'retention' area. A dry well certainly would mitigate all that water before it could run into the creek from the surface. – stormy Dec 13 '17 at 22:16
  • A dry well is simply a large hole (4' deepX6'wide for an example, need to know amount of water during rains) lined with landscape fabric, filled with 1 1/2" drain rock, covered with landscape fabric then soil or gravel or more cobble to finish your 'dry stream'. – stormy Dec 13 '17 at 22:17
I think you are on the wrong side of that retaining wall. You want to intercept the water in the soil, before it reaches any structure that water will corrode or erode. Drain pipes go BEHIND the wall on the side with the surcharge, the soil that that wall or foundation is holding back. They are also always lower than the footing of a foundation or wall or stair system. You want to use a perforated 4" plastic pipe below the footing (not on top of the footing) on the up hill side. Water flows through the soil to collect in this pipe to be drained away.
Dig a trench coming at us in the picture from the outside of the edge of your stairway, walkway. Looks like 4' from the foundation to the left and parallel to the home. Dig a trench as deep as the foundation's footing. If there is a basement this depth could be a good 6 to 8 feet deep and 2' wide. Install landscape fabric, a few inches of drain rock, install the perforated drain pipe wrapped in landscape fabric, the bottom of that pipe being LOWER than the foundation footing. Back fill with drain rock, use landscape fabric on top so that soil is unable to mix with the drain rock, top with soil or better, gravel.
Absolutely no water should be able to drain towards the concrete foundation. The perf pipe is always just below the lowest part of the footing of your foundation. That pipe has a definite slope towards your chosen drain outlet. That pipe should be at the very least 3' below the surface if you live with winters.
The second option would be if you find your foundation drain system is non existent or non functioning, I would pull all of that soil completely back from the foundation, re coat the asphalt on your foundation, allow to dry, install proper foundation drain system with drain rock, landscape fabric, more drain rock...either tying into the original system if it works at all or doing the entire foundation with fresh asphalt, foundation drain pipe system, landscape fabric. The subsurface soil has to slope away from your foundation. The perf pipe helps to collect any water that gets close to your foundation and diverts it away to either a sewer water system or a daylighted drain. Depends on your restrictions.
This is probably one of the most important aspects for the value of your home. Drainage. Without drainage the foundation will be short term. You'll get mold that could be very hazardous to some people's health. When considering any project that will need some heavy machinery the best advice is to get as much as possible done when the equipment is there the first time. I would ask for bids but chose the one who is able to see the entire project scope best such as calling for utility location, what to do with soil/debris, etc... not the one who is cheapest. Also, make dang sure they are licensed and insured have insurance of their own.
What I think you are trying to do is on the wrong side of that retaining wall. To amend your system those stairs get pulled out so you are down to the level of your footing. If you do not have a decent periphery foundation drainage system, I would consider redoing that entire system to do at this time. Best and cheapest in the long run. A good fix would be to just do this one side on the outside of that wall not the inside.
Procuring bids which also means professional advice is free and very valuable even if you decided to DIY.
You are thinking about day lighting your foundation drainage that is near a stream to run into that stream? That is a major no no with the rules in this country. Where exactly is it you live? All rivers, creeks even intermittent creeks have buffer zones that no one owns in this country. It is a very good thing but those who have riparian systems on their property usually learn that they truly don't OWN that part of their property. Please send more information. Giving answers about drainage based on little information is frankly irresponsible. Of ME. Please help by adding any information you can think of to help us be more responsible.
  • It's not at an issue at all to dump into the stream from any property drainage where I live (Oregon coast). Every drain in my neighborhood / all homes do this at some point and those drains run right into the ocean 100 yards away. The way the laws work here, unless it's a named creek (mine isn't) you're pretty safe. In fact, it is illegal for any organization to claim ownership of ground water. I was told by the county water person that I could literally put in Micro Hydro, drain my roof into the creek that runs down the hillside / do whatever I want cause it's just a "drainage" creek. – maplemale Dec 13 '17 at 23:16
  • None of that is what I wanted to hear of course. LOL Not sure foundation drainage recommendation (below footing) is plausible. My footing stops at around 13ft deep (not 6-8). I'm not certain how far away from the foundation they cut into the hillside. But doubt it's more than 12"? In any case, getting an excavator in there was possible before my house was built. Now it's not. I'm not sure it would cut thru the sandstone anyway. My 1 acre has 130ft elevation front to back. The house is cut deep into a hillside with a half basement (downhill) and 12ft deep crawl space (uphill) with a pony wall. – maplemale Dec 13 '17 at 23:33
  • That is some slope. Excavators should be able to get to your home, they had to be there at the beginning. The difference in depth between 6 and 13 feet is negligible in cost. There are no other options to protect your home and your home's value other than focus on basic working drainage. All soil has to slope away from your home. You must have a foundation drain system. Behind your home there should be at least 4 to 6 feet sloping away from foundation and into a serious swale ( a ditch to direct water around and down slope). There are also cheap laborers to wield shovels – stormy Dec 14 '17 at 07:02
  • How long ago did you purchase your home? Oregon. Gee, guess where I live now? It is illegal to sell a home with such bad drainage. They call this 'discovery' and there is a large window for this problem. Did you go through a bank? If you did then you might have some power here to get help financially. A home snuggled into the hillside with a lame foundation drain and not even sloped foundation soils? I taught this stuff University level and built 30 custom homes on difficult sites. In Washington State the state warranty is 12 years from occupancy permit holding the contractor liable. – stormy Dec 14 '17 at 07:12
  • Nice, a fellow Oregonian! So, you know what kind of rain volume I'm dealing with. I covered the entire area in black plastic, dug up the downspouts and shot them down the hill. Eliminated 90% of crawl space water. Still a trickle, but now it's obvious. The water is coming from 30 inches below the vent. So, I dug that area up and found a 8" junk greenhouse pipe running mostly vertical that had the crap beat out of it and leaking water everywhere. The mystery deepens... never seen that pipe anywhere else but it's clearly directing water up against the foundation. – maplemale Dec 21 '17 at 02:12
  • Excellent measures, take pictures. This is not at all a home that should have be on the market until these problems were solved. That is a fact. You know, I would hire a private building inspector. This is their job and believe it or not their invaluable information was under $200. Totally admissible in court. Do not want to go that way but you do have a very eligible case. The only way to fix this is to get heavy machinery, experience and know how that is certified to correct this MAJOR problem. Or your house just might end up slip sliding down the slope as well. – stormy Dec 21 '17 at 03:47
