58 Ghia Restoration Begins
Page: Previous  1, 2, 3 ... 12, 13, 14, 15  Next
VeloMikey
VeloMikey is offline
PostPosted: Tue Dec 03, 2024 1:04 pm    Post subject: Re: 58 Ghia Restoration Begins Reply with quote
kingkarmann wrote:
VeloMikey wrote:
kingkarmann wrote:
I always look forward to the updates.
Simply amazing work.
Are you planning on using later marker lights?
I am not sure what you are asking. Those are the correct turn signals for a December 1957 KG.
What is a "later maker light"?
FYI, I have NOS turn signal housings and headlight rings.
I thought they look very similar to the later Ghia's.
I thought all lowlights had a similar front markers like this.
After looking at 57's and 58's it's plain to see I was wrong.
Learned something new. Carry on Smile
That's the beauty of (early) 58s. Bullet turn signals, dashes with side rib details, no dash pad, tall battery hold down and straight not angled rear upper shock mounts on the pan. Subtle little differences.
WrennMetallWerks
WrennMetallWerks is offline
PostPosted: Tue Dec 03, 2024 1:10 pm    Post subject: Re: 58 Ghia Restoration Begins Reply with quote
^^^ We all do my friend ^^^
That’s one of the cools things about the forums. So much to learn.
Purpose Over Pleasure 🕊
“Hard Werk ⚒ God First
WrennMetallWerks
PostPosted: Tue Dec 03, 2024 5:04 pm    Post subject: Re: 58 Ghia Restoration Begins Reply with quote
That was quite the journey….
Yet rewarding at the end. The hinges are tight and smooth and good to go for another lifetime….
WrennMetallWerks
PostPosted: Tue Dec 03, 2024 6:08 pm    Post subject: Re: 58 Ghia Restoration Begins Reply with quote
Making things
PostPosted: Wed Dec 04, 2024 3:46 am    Post subject: Re: 58 Ghia Restoration Begins Reply with quote
There was I thinking a lathe in the workshop is a cool addition, but a CNC? Outstanding.
Nicholas
WrennMetallWerks
PostPosted: Wed Dec 04, 2024 10:35 am    Post subject: Re: 58 Ghia Restoration Begins Reply with quote
Door Days are here again.
WrennMetallWerks
PostPosted: Wed Dec 04, 2024 1:29 pm    Post subject: Re: 58 Ghia Restoration Begins Reply with quote
Lots to sort out on the doors.
WrennMetallWerks
PostPosted: Wed Dec 04, 2024 1:31 pm    Post subject: Re: 58 Ghia Restoration Begins Reply with quote
Nicholas
Making big things happen….. This and so many other cool machines belong to my neighbor…. I’m feeling pretty blessed, he has been super patient getting this program rite.
WrennMetallWerks
PostPosted: Wed Dec 04, 2024 1:51 pm    Post subject: Re: 58 Ghia Restoration Begins Reply with quote
This side hammer area on the door is going to take some techniques and patience to get back to good. These old repairs cause so much damage and stress on the metal.
I came up with this really effective way to use VW parts to fix VW parts Laughing
I used a torsion cover plate and a shift couple screw to raise the sheet metal back up. This is one of many steps I will take to try to understand what the metal will need to do to find its way home.
It’s hard to tell in the photos how much I’m moving the metal but I can say it is quite a bit. I’m trying hard to not over pull it but at the same time I’m trying to get it just past flush a bit so when I weld it I can hit it with compresses air to shrink the stretched metal and have it settle down to flush with the surrounding area.
WrennMetallWerks
PostPosted: Wed Dec 04, 2024 2:32 pm    Post subject: Re: 58 Ghia Restoration Begins Reply with quote
So in the effort to control the metal I need to use the the the jack to try to raised a large area of the door that was collapsed from the original damage and then again from the force of the slide hammer pulling outwardly. I will crank the jack into the contour gauge tells me that it is as it should be ( like the rest of the undamaged parts of the door). I will leave that jack in that position while I use the dent fix machine to pull the last of the low spots. The goal is to get everything as smooth as u can before the welding begins.
WrennMetallWerks
PostPosted: Wed Dec 04, 2024 4:47 pm    Post subject: Re: 58 Ghia Restoration Begins Reply with quote
WrennMetallWerks
PostPosted: Wed Dec 04, 2024 6:12 pm    Post subject: Re: 58 Ghia Restoration Begins Reply with quote
WrennMetallWerks
PostPosted: Wed Dec 04, 2024 6:35 pm    Post subject: Re: 58 Ghia Restoration Begins Reply with quote
WrennMetallWerks
PostPosted: Thu Dec 05, 2024 10:18 am    Post subject: Re: 58 Ghia Restoration Begins Reply with quote
Unfrozen…
WrennMetallWerks
PostPosted: Thu Dec 05, 2024 1:07 pm    Post subject: Re: 58 Ghia Restoration Begins Reply with quote
VeloMikey
PostPosted: Thu Dec 05, 2024 2:17 pm    Post subject: Re: 58 Ghia Restoration Begins Reply with quote
More updates...
Jason had a correct Lowlight deck lid latch laying around the shop so he threw it on.
He also got the drivers door hung with the freshly rebuilt hinges. Check out
how smooth it opens and closes! Also look at the gaps. Near perfect without much attention.
Link
WrennMetallWerks
PostPosted: Thu Dec 05, 2024 5:17 pm    Post subject: Re: 58 Ghia Restoration Begins Reply with quote
WrennMetallWerks
PostPosted: Thu Dec 05, 2024 5:19 pm    Post subject: Re: 58 Ghia Restoration Begins Reply with quote
WrennMetallWerks
PostPosted: Thu Dec 05, 2024 5:34 pm    Post subject: Re: 58 Ghia Restoration Begins Reply with quote
WrennMetallWerks
PostPosted: Thu Dec 05, 2024 5:35 pm    Post subject: Re: 58 Ghia Restoration Begins Reply with quote
Page 13 of 15
