What's this Ghia part and Where does it go?
Page: Previous  1, 2, 3 ... , 35, 36, 37  Next
Michaellatini
Michaellatini is offline
PostPosted: Sat Aug 05, 2023 6:08 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Hello All,
Do you know what these parts are and where they go? 1968 Coupe.
Thank you,
Michael
kiwighia68
kiwighia68 is offline
PostPosted: Sun Aug 06, 2023 10:26 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Michaellatini wrote:
Hello All,
Thank you,
Michael
Behind the wheel arches in the luggage compartment behind the back seat. The one at the top has an aperture for the warm air tube coming towards the front.
Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015
Michaellatini
PostPosted: Sun Aug 06, 2023 3:22 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Kiwi,
Thank you for the information.
M
Marcdeb
Marcdeb is offline
PostPosted: Mon Aug 07, 2023 6:48 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Hello All,
Thank you,
Michael
I found similar pieces in the same area over the rear wheel wells of an a 71 Karmann Ghia Vert with all original interior. They look a little different but are these the same parts as found on the 68 above? Only the left side has a hole in the center. What is the purpose of the hole?
Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
Trylon
Trylon is offline
PostPosted: Mon Aug 07, 2023 6:52 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Hello All,
Thank you,
Michael
Huh, that seems like a different part. The other ones were meant to cover a hole and show. Did yours show or were they under something?
1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel!
Marcdeb
Marcdeb is offline
PostPosted: Mon Aug 07, 2023 7:10 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
On the 71, it is hidden by the carpeting, and the lower rear portion of the headliner. It might be different due to the 68 are from a coupe and mine are from a Vert. In addition, after 69.5 the convertibles tops had gone through a major change with a glass rear window. The sides of the rear seat area were changed as well.
Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
WestyMeg
WestyMeg is offline
PostPosted: Mon Aug 14, 2023 11:25 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Hi all!
My '68 coupe Ghia has no dash emblem and I'm hoping someone has a pic of the correct placement for it so I can replace it correctly.
Thanks in advance!
Why is the rum gone?!
1968 Karmann Ghia-some fancy white
1985 Westfalia-some crap brown
1971 Opel GT-hubby's first car
1974 914-mostly rust colored
2007 Cayman S-Sapphire Blue (so pretty!)
Marcdeb
Marcdeb is offline
PostPosted: Mon Aug 14, 2023 11:37 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Here's my all original 68 Dash. Even the sticker for the Autostick shift pattern is original which is visible behind the right side of the steering wheel.
Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
WestyMeg
WestyMeg is offline
PostPosted: Mon Aug 14, 2023 11:54 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Thanks! My dash has no opening for a radio, is that usual? Seems odd to have nothing at all. The dash is probably aftermarket if I had to guess.
Marcdeb
Marcdeb is offline
PostPosted: Mon Aug 14, 2023 1:03 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Radios were dealer installed so Ghia's didn't have radios when they left the Karmann Factory. The earlier painted dash had blank plates to cover the radio hole. The dealer had to cut a hole in the wood laminate to install the radios. Back then not everyone wanted a radio. My how times have changed! Laughing
Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
c21darrel
c21darrel is offline
PostPosted: Mon Aug 14, 2023 3:03 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Post a pic.
GhiaBuild
1967 DC build
Marcdeb
Marcdeb is offline
PostPosted: Mon Aug 14, 2023 3:51 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
If your dash is original, you should have a wood grain laminate and at least have holes from where an emblem used to be. Since you don't seem to have existing holes, your dash must have been recovered. An original dash that has never had a radio would look like pictures 27 & 31 in this link.
https://bringatrailer.com/listing/1967-volkswagen-karmann-ghia-15/
Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
WestyMeg
WestyMeg is offline
PostPosted: Tue Aug 15, 2023 1:43 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Here's a pic of my dash.
No wood grain laminate, it appears to be some kind of sheet metal.
Humorously it has a Maine state quarter in the middle of the glove box knob. I bought from a man in Maine. As amusing as it is to me, I'm going to get a locking knob so it will have to go. Sad
Marcdeb
Marcdeb is offline
PostPosted: Tue Aug 15, 2023 2:22 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
I suspect the wood grain laminate has been remove and the dash painted, or it's possible that a black laminate was put on over the metal dash after The black dash started in 1972 through the final year of production in 1974. if you look at the back side of the dash, from the front trunk, you should be able to see what was done. Look for the holes for the insignia. Looks like the inside top of your doors got the same treatment. Also check the back side of the glove box door. You might see overlap of the black laminate or maybe just paint?
Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
bugnutt
bugnutt is offline
PostPosted: Sun Sep 24, 2023 2:25 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
I found these bolts (M10x1.5mm) with parts from a car with an 11/55 front end and the back from a 10/56 car. I've looked through the parts book but can't find them. Anyi ideas
jeffrey8164
jeffrey8164 is offline
PostPosted: Thu Sep 28, 2023 6:34 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
They look like bumper bolts?
Volkswagen!
(Compression 8.7:1)
NoDents
NoDents is offline
PostPosted: Thu Sep 28, 2023 8:14 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Yes, number bolts... should be chrome.
No Dents
1963 Bug - Sold in 1980
1966 Karmann Ghia Convertible - Stolen in 1988
1971 Karmann Ghia Convertible, resto/mod COMPLETED 10/2020
bugnutt
bugnutt is offline
PostPosted: Thu Sep 28, 2023 6:27 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
I thought that too at first but these are 10mm bolts, the parts book says 8mm. Probably not VW
obus Premium Member
obus is offline
PostPosted: Fri Dec 22, 2023 1:41 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Interior pieces related to windlace????
Loren Premium Member
Loren is offline
PostPosted: Fri Dec 22, 2023 2:34 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Those little plates go on the doors and cover the ends of the hinges. I believe 60 was the last year to use them. You should have two per door.
Page 36 of 37
