chrisurban Samba Member
Posted: Mon Feb 27, 2023 10:45 am Post subject: Re: What's this Ghia part and Where does it go? |
Marcdeb wrote: |
The numbers "4 65" is for April 1965 I believe. I'm not 100% sure, but it does not look like it matches the 65 Ghias. |
Iâm wondering if this is from a Type 3 Ghia - I donât recall the early Ghias having the shift pips. |
FunkyOldPatina Samba Member
Joined: October 13, 2012 Posts: 207 Location: Sunny UK!
Posted: Tue Apr 11, 2023 12:22 pm Post subject: Re: What's this Ghia part and Where does it go? |
Is this for a KG oil bath setup? It looks to be but I've not seen the exact same part in the classifieds or on a google image search?
Thanks all.
EverettB  Administrator
Joined: April 11, 2000 Posts: 71336 Location: Phoenix 602
Posted: Sat Apr 15, 2023 9:28 am Post subject: Re: What's this Ghia part and Where does it go? |
EverettB wrote: |
Yes, Ghia and Bus 1500cc piece for on top of the carb.
1966 Ghia example from Gallery
Thanks Everett!
It was the rubber tube on the right of the part that had me confused  |
iowegian  Samba Curmudgeon
Joined: February 16, 2005 Posts: 9935 Location: Somewhere between Dubuque and Keokuk
Posted: Sun Apr 16, 2023 1:58 pm Post subject: Re: What's this Ghia part and Where does it go? |
I know what this is and I know where it goes, but what years and which side?
The metal screen is about 6" wide, 3" high, 4 1/2" deep.
Maybe it's left over from when I owned a '61? I had a '70, but those screens were plastic.
c21darrel Samba Member
Joined: January 22, 2009 Posts: 8233 Location: San Dimas
Posted: Mon Apr 17, 2023 4:20 am Post subject: Re: What's this Ghia part and Where does it go? |
c21darrel wrote: |
The ones with an upper case "L" go on the left side. The ones with an upper case "R" go on the right side.
It looks a little bent, i have a couple that are more rectangular. I couldnt get the 3rd screw out to determine L or R, one way the screw holes line up, the other fits but screw holes dont line up. Sorry not more help Chuck. Maybe once the "Blaster" seeps in... |
There is no "L".
There is no "R".
There are no screw holes.
It might be slightly bent, but the lower right corner is 90 degrees (+/- 15 minutes) while the included angle of the lower left corner is 60 degrees.
EDIT: this must be left (driver's) side isn't it?
Loren  Samba Member
Posted: Mon Apr 17, 2023 11:35 am Post subject: Re: What's this Ghia part and Where does it go? |
That is for the driver's side. It's for a low light Ghia. 60 on up Ghias had rectangular openings on the screens. |
Posted: Mon Apr 17, 2023 4:54 pm Post subject: Re: What's this Ghia part and Where does it go? |
Thanks Loren---I have no idea how I ended up with a Low-Light part.  |
kingkarmann Samba Member
Posted: Tue Apr 18, 2023 6:12 am Post subject: Re: What's this Ghia part and Where does it go? |
iowegian wrote: |
Perhaps we may talk about in the "Example of Overpriced Ghias & Ghia Parts" thread?  |
Posted: Tue Apr 18, 2023 9:07 am Post subject: Re: What's this Ghia part and Where does it go? |
kingkarmann wrote: |
iowegian wrote: |
Indeed.
I was thinkin' about a hunert and fitty bucks.  |
John Moxon  Samba Moderator
Joined: March 07, 2004 Posts: 14174 Location: Southampton U.K.
Posted: Wed Apr 19, 2023 3:23 am Post subject: Re: What's this Ghia part and Where does it go? |
Really struggling with this torsion bar/rod.
Its 59cm/23.25 inches long and approx. 1.5 inches max diameter.
and I can't think what it would fit. Is it a late Ghia part please?
wagen19 Samba Member
Joined: November 16, 2007 Posts: 557 Location: germany
Posted: Sun Apr 30, 2023 11:22 am Post subject: Re: What's this Ghia part and Where does it go? |
FunkyOldPatina wrote: |
Hi, torsion bars 590 mm long are for type 2, march´55 till july 67 |
Posted: Wed May 03, 2023 3:56 am Post subject: Re: What's this Ghia part and Where does it go? |
Thank you wagen19, you're a star!
Cheers dude  |
blue72beetle Samba Member
Joined: April 23, 2008 Posts: 893 Location: Fort Wayne, IN
Disc Samba Member
Joined: September 24, 2009 Posts: 628 Location: Europe
Posted: Mon May 15, 2023 10:56 pm Post subject: Re: What's this Ghia part and Where does it go? |
Yes, it is. _________________ The glory never gets old, just need new paint.
Nick |
pizza442 Samba Member
Joined: December 26, 2022 Posts: 2 Location: Dana Point, CA
Posted: Mon Jun 12, 2023 12:30 pm Post subject: What's this Ghia part and Where does it go? |
I know these look familiar but not having a car to run over to check, I can't think of what these knobs are for?
Peeteboy2 Samba Member
Joined: April 01, 2023 Posts: 38 Location: Encinitas, Ca.
Posted: Thu Jun 15, 2023 8:42 pm Post subject: Re: What's this Ghia part and Where does it go? |
Not sure if I'm posting this correctly but any idea what these are exactly. Thanks 68 Coupe
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 4101 Location: In Molinya Orbit
