What did you do to your ghia this week?
Page: Previous  1, 2, 3 ... , 167, 168, 169  Next
kiwighia68
kiwighia68 is offline
PostPosted: Thu Jul 25, 2024 5:22 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
I did not restore Emiko so that she could sit in the garage.
Driving in the rain.
Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015
PostPosted: Fri Jul 26, 2024 1:48 am    Post subject: Re: What did you do to your ghia this week? Reply with quote
Indeed lots of driving rain in Auckland of late.
Nicholas
Katana68
Katana68 is offline
PostPosted: Fri Jul 26, 2024 9:20 am    Post subject: Re: What did you do to your ghia this week? Reply with quote
Bought first ghia 68. was told ran good with 1600cc had it transported to my home. it drove about a mile n half and quit running. been working on it since started with spark plugs and it just kept opening doors to everything else it needs fixing or tuning. carbs are way out of tune running on mostly gas its so rich. and found that it's a 1915cc dual port with idf 44 webers so that's cool. as long as it starts back up again when I'm done. fingers crossed 🤞
Steelz21
Steelz21 is offline
PostPosted: Thu Aug 08, 2024 12:23 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
I had some free time this week so I made a footrest, total cost $0
Steelz21
Steelz21 is offline
PostPosted: Thu Aug 08, 2024 12:25 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
I also found time to finally install these door card protectors as I am sick of marking them up when I swing my big size 12’s in.
Steelz21
Steelz21 is offline
kiwighia68
PostPosted: Thu Aug 08, 2024 12:29 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
Where did you source those door card protectors, please?
Steelz21
Steelz21 is offline
PostPosted: Thu Aug 08, 2024 2:00 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
The door card protectors came from CIP-1.ca as I am in Canada , CIP-1.com if you are in the USA.
Andy
kiwighia68
PostPosted: Thu Aug 08, 2024 3:05 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
Andy
Much obliged, Andy. I'm going to order a set.
Chris M
Marcdeb
Marcdeb is offline
PostPosted: Thu Aug 08, 2024 3:44 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
Those look great! Nice extra bling.
Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
Exnermobiles
Exnermobiles is offline
PostPosted: Sun Aug 11, 2024 4:23 am    Post subject: Re: What did you do to your ghia this week? Reply with quote
Made a weekend trip from Finland to Sweden with my '62 coupe.
1962 Karmann Ghia Coupe
1958 Plymouth Belvedere Sport Coupe
1959 Dodge Sierra STW
Rome
Rome is offline
PostPosted: Sun Aug 11, 2024 5:17 am    Post subject: Re: What did you do to your ghia this week? Reply with quote
Excellent photos, Exner! First one looks like it could be right out of the '60's. Except for those white markings on the pavement...
rbsurfguy
rbsurfguy is offline
PostPosted: Tue Aug 20, 2024 10:18 am    Post subject: Re: What did you do to your ghia this week? Reply with quote
So as reported previously, I was having an oil leak problem from my lower pulley, somehow the sand seal was failing and allowing oil to seep and get blown all over my engine.
I finally found a good local VW mechanic, who owns his own awesome Bug and Notchback, so took it to him to fix the problem. He had and installed a new tighter fitting sand seal, tightened everything down, and the oil stopped blowing out. I had also taken the advice from members here and in the Performance section to reduce the oil level, which I think also helped. Special thanks to 74Thing, Brandon, for reaching out on PM to give me a bunch of things to check and some resources to read!
While my Ghia was in his shop, I had him finally tune in the carbs. He noticed on my build sheet that the idle jets were 45's and he felt they should have been 50's, which he installed. I don't know enough about jetting to question it. I figured since he has a 68 Bug and a 64 Notchback, with race engine, as well as a Porsche with air cooled engine, he would know about these things, which he did.
Also had him align my front end, and for fun he fixed the horn! I only get a lite shock if my arm is on the door chrome, but it works and keeps me awake!!
Drove out with my local VW Crew, Capital VW Club, to the VW Nationals at Mason Dixon dragstrip last weekend in Maryland, and the Ghia ran soooo smooth! She wants to go full out but I had to cruise at a reasonable speed, NO flat spots, slight push on the pedal and she moves. I'll have to find a long open road to see how she'll run at full speed, to a degree!!
At the end of the day, I picked up a top 20 award out of about 60 or so cars on display, so not a bad day or week! I like the shows where the spectators judge and submit their choice instead of judges who seem too picky.
Back to tinker on more stuff until the next disaster!!!
Jeff
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Steelz21
Steelz21 is offline
PostPosted: Wed Aug 21, 2024 6:42 am    Post subject: Re: What did you do to your ghia this week? Reply with quote
Well deserved, your car is a beauty.
Steelz21
Steelz21 is offline
PostPosted: Thu Aug 29, 2024 12:18 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
I finally got around to lining the hood and making a carpet cover for gas tank area. It cleans everything up I think and hopefully stops a bit of noise. There is a foam panel under the carpet.
Andy
PostPosted: Fri Aug 30, 2024 2:56 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
Annual inspection and registration time. Here.'s the Ghia hanging out in the inner city workshop with the daily drivers. Although much older we know which one is better looking.
Then I took it for a drive and enjoyed it.
Nicholas
Lynchy99
Lynchy99 is offline
PostPosted: Fri Oct 11, 2024 7:17 am    Post subject: Re: What did you do to your ghia this week? Reply with quote
Andy
Like the wiring cover, where is that from? thanks
Steelz21
Steelz21 is offline
PostPosted: Sun Oct 13, 2024 12:14 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
CIP1 special ordered it for me as they don’t normally stock that one.
It works out cheaper for me to do it that way as I don’t end off paying duty when it comes across the border to Canada, and they ship for free on orders over $100.
I think they ordered it from Airhead parts in the US.
Andy.
rich caramadre
rich caramadre is offline
PostPosted: Sun Oct 13, 2024 6:31 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
After 3+years of working on it on and off I finally got the 58' in paint.
Steelz21
Steelz21 is offline
PostPosted: Sat Oct 19, 2024 8:19 am    Post subject: Re: What did you do to your ghia this week? Reply with quote
I love that colour.
Very unusual.
Page 168 of 169
