Photo Resizing
Page: 1, 2, 3  Next
Forum Index -> Site Share: Facebook Twitter
PostPosted: Fri Dec 10, 2004 4:52 pm    Post subject: Photo Resizing Reply with quote
To upload photos for Classified Ads or into the Photo Gallery on the site, you often need to resize the photos that your digital camera takes. Current digital cameras take photos that are very large, as they are suitable for printing, but the large size is not necessary for use on the Internet.
Various resizing programs and tips are below.
For Classified Ads:
If you are placing a Classified Ad and cannot get the photos to work, if the ad won't place or "times out," or you get returned to the login screen, this means your photos were too large. If you cannot get them resized - Place the ad with no photos then email them to me - EverettB at [email protected]
I will re-size and add them for you.
Resizing Programs
Windows 7/8/10
ImageResizer:
http://www.bricelam.net/ImageResizer/
Mac
Resizing on a Mac using iPhoto:
Under your FILE menu in iPhoto you have the EXPORT option. Select it and you will see that you have the option to resize an image.
Another Mac program:
http://www.versiontracker.com/dyn/moreinfo/macosx/32838
Windows XP, download this program and install it:
http://download.microsoft.com/download/whistler/Install/2/WXP/EN-US/ImageResizerPowertoySetup.exe
Then, right click on the saved picture and hit resize pictures. Then click advanced, then custom, and make it 640 x 480 for classified photos, 100x100 for avatars.
Vista:
A member contributed:
Try http://www.drpic.com/
Easy to use / works with vista / and super easy
Resize to 25% apply and save to disk
Member vwed ed says
"I've downloaded Windows Live Photo Gallery. This stores all my pictures in parallel with My Pictures etc. In the Gallery mode it is very easy to resize photos via a few clicks:
http://download.live.com/photogallery
Photoshop
Use Save for Web, Medium quality on the menus
Tutorial later in this thread
Other
IrfanView - Freeware Graphic Viewer and more
http://www.irfanview.com
The FastStone Photo Resizer:
http://www.faststone.org
Gimp (Graphic Image Manipulation Program).
http://www.gimp.org/
If none of the downloads work on your computer for whatever reason, you can also try this online photo re-sizer:
http://webresizer.com/resizer/
covelo
covelo is offline
PostPosted: Tue Mar 22, 2005 9:24 pm    Post subject: Reply with quote
Does anyone know how to get the file size down below 8k in iPhoto? Even at 15x15 it is still 8k.
PostPosted: Wed Mar 23, 2005 8:23 am    Post subject: Reply with quote
I don't know the answer for iPhoto but it has to do with the JPG "compression ratio" if a 15x15 image is still 8k. Look for where to change that setting
PostPosted: Fri Jul 22, 2005 9:58 am    Post subject: Reply with quote
Here are some instructions for using the XP Program "ImageResizer," mentioned in this first post in this thread:
1. Locate the picture(s) on your computer. In the image below, I am resizing a single photo and it located on my desktop:
2. Right click on the image (as seen above) and select Resize Pictures
3. A box will pop up:
4. Using the box above, select the Small option for Classifieds photos and press Ok
5. After hitting Ok, you will now have 2 files:
6. Use the (Small) file as the photo for your ad.
Tip:
If you have more than one photo, you can select all of them and right click on one to resize all of them at once:
If you have Paint Shop Pro (or a trial version of it):
1. Open image
2. Select Image -> Resize on the menus
3. Change size to 640x480 (or whatever)
4. Make sure you save in JPG format.
If you don't have a commercial product, you can use the free "Paint" program that comes with windows.
Steps for Paint:
1. Open image
2. If you don't know the size of your image already, select Image -> Attributes from the menu. Note the size, it will probably be something like 1280 by 960
3. Select Image -> Stretch/Skew from the menus.
4. Change the percentages. If the image is 1280x960, use 50% to shrink it down to 640x480 pixels in size.
5. Save your image.
6. Upload to site.
mattt
mattt is offline
PostPosted: Sun Oct 23, 2005 7:08 pm    Post subject: Reply with quote
1. Open image
Steps for Paint:
1. Open image
5. Save your image.
6. Upload to site.
Im trying this with the "Paint" program in XP. Im starting with a 119k image. No matter how much I Stretch/Skew it, even down to 5%, its still 7.xx KB.
I tried downloading the ImageResizer, and since this is a work computer it wont take the download.
Any other suggestions?
spkncarl
spkncarl is offline
PostPosted: Tue Nov 08, 2005 10:42 am    Post subject: Reply with quote
O.K. I need help also. I did the right click, resize pic, advanced, custom and then 100x100 for the avatar and I'm still over 6 kb also. Help!!! Crying or Very sad
Jessica
Samba Chat Whore
Jessica is offline
PostPosted: Tue Nov 08, 2005 11:08 am    Post subject: Reply with quote
I use Adobe Photoshop and use the Save for Web option (as stated before this comes out medium quality, but it still shows up perfectly fine for avatar use). If anyone would like me to resize avatars for them, I would be happy to help.
If you are more of a do-it-yourself type person, I would suggest downloading the program Irfranview (this was also previously posted in this thread). It's a very easy to use program. If you need help using it, I would be more than happy to help you with that as well.
EDIT: I no longer have a program to resize pictures. I would like to help, but it's not possible anymore.
VW-less right now...looking
-OGST-
RIP HBB
RIP RW
Quote:
MrBreeze: The snorklestang has no history. It was here before time began. Jesus himself drove that to high school
View user's profile Send private message Send e-mail Facebook Gallery Classifieds Feedback
spkncarl
spkncarl is offline
PostPosted: Tue Nov 08, 2005 7:49 pm    Post subject: Reply with quote
Thank You Jessica, I really appreciate your help. Laughing Wink Laughing
I'm still messing around with it to try and figure out what I'm doing wrong. Embarassed
PostPosted: Wed Nov 09, 2005 9:13 am    Post subject: Reply with quote
You are probably doing everything right but the program is not able to change the JPG "compression" setting so your photo can't become small enough.
mschilling
mschilling is offline
PostPosted: Mon Dec 05, 2005 7:48 pm    Post subject: Reply with quote
Can I post a link (url or otherwise) to a pic on Photobucket.com instead of uploading the pic when I place an ad?
PostPosted: Mon Dec 05, 2005 9:19 pm    Post subject: Reply with quote
Not for the Classifieds, external photos are not allowed.
crofty
Judas of the North
crofty is offline
PostPosted: Mon Dec 12, 2005 11:40 pm    Post subject: Reply with quote
I was able to download the 640X whatever size from my camera to my pc with the software it came with.
Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote:
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine.
HamburgerBrad
Je suis Napoléon!
HamburgerBrad is offline
PostPosted: Tue Dec 13, 2005 12:05 am    Post subject: Reply with quote
maybe a little more advanced tutorial on how to do it with photoshop using "Save for Web". for this, i used photoshop 7. i have no idea what's current, i can only assume the layout hasnt changed much
1. open the desired image with photoshop
2. crop it to size, or leave the proportions as is
3. from the "File" menu, select "Save for Web..."
4. in the new window that appears, select the "Image Size" tab. from there, set the larger of the two numbers to 100, since this is the max size for avatars on thesamba.
5. click on the arrow inside the white circle. this brings down another menu. there, select "Optimize to File Size..."
6. set the desired file size to 6KB, since this is the max file size for avatars on thesamba
7. once the file is the correct size, click on save and then upload that image to your profile in the Control Panel as an avatar
OGST | CU05 | OGJHC
1970 baja|1953 oval
Wanted: two beat up, ugly, curb rashed 6" phone dial wheels
PostPosted: Tue Mar 14, 2006 3:14 pm    Post subject: Reply with quote
GangsterWhiteWalls
GangsterWhiteWalls is offline
PostPosted: Fri May 26, 2006 11:42 am    Post subject: Reply with quote
is there a way to use microsoft paint to resize without loosing image quality. my pictures get ridiculously pixelly when i shrink them
-since i am using a work computer, i cannot download programs. that is why i am asking a ms paint question.
HamburgerBrad
Je suis Napoléon!
PostPosted: Fri May 26, 2006 11:57 am    Post subject: Reply with quote
i've had better luck with microsoft photo editor (comes with the MS Office pack?) than with paint.
OGST | CU05 | OGJHC
1970 baja|1953 oval
PostPosted: Fri May 26, 2006 3:15 pm    Post subject: Reply with quote
What size are you doing? I tried on a 1280x1024 picture I have, resizing it to various smaller sizes and lost no image quality.
GangsterWhiteWalls
PostPosted: Fri May 26, 2006 3:18 pm    Post subject: Reply with quote
i have actually had mixed luck with ms paint. i have two different pictures that are taken from two different digital camera (don't have specs on me). but my avatar that i just put up looks ok to me. picture was taken nightish so background is dark. its ok though.
mrldiz
mrldiz is offline
PostPosted: Sat Sep 09, 2006 7:51 am    Post subject: Thanks a Million Reply with quote
Very Happy This information was extremely helpful and time saving. Thank you to all of you who took the time to post accurate and useful information! Much Appreciated!
Russ Wolfe
Russ Wolfe is offline
PostPosted: Mon Sep 25, 2006 8:04 pm    Post subject: Reply with quote
For those on a limited budget, you can get a free program called The Gimp (Graphic Image Manipulation Program).
It can be downloaded for free here.
This was started as part of the Linux movement, but has been ported over to Windows.
There are no Spyware, or AdWare attached to this program, and it has about the same power as Photoshop, without having to pirate it from your buddy, or use a crippled version.
Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop.
Reply to topic    Forum Index -> Site All times are Mountain Standard Time/Pacific Daylight Savings Time
Page: 1, 2, 3  Next
Page 1 of 3
